Resolved 2021 New Aire Silverleaf Bathroom Panel Frozen
RanDon 3543
We are on the road for 3 weeks and our bathroom wall panel has frozen. No lights, fans, etc. in the bath area. All other panels are working fine. Any thoughts or suggestions would be appreciated.
Have you tried shutting your Silverleaf completely off.
Have you tried removing the panel, unplugging the connector that goes into it, waiting 5 to 10 seconds, and then plugging that back in to reset the panel? If I recall it is pushed into the wall and held in place with spring clips. One easy way to practice this and see how it is held is place is up in the main area of the coach where there is a panel on the front valence next to the theatre seats / sofa on that floor plan. Since you have access to the front and back of the valence where the panel goes you can get a feel for how its sister panel is mounted in the bathroom.
The other thing you can do is remove the main screen on the opposite side of the wall in the hallway (held with screws) and once removed gain access inside the wall to check connections. Your LR125 module will also be hidden in there, which provides Silverleaf's WiFi and myRozie access. The only problem is that main panel sits higher up the wall than the bathroom panel on the other side, but may get you a way to put eyes on it.
Best,
-Mark
I have not tried removing the panel. I can take look and see what I can do. Those things are usually pretty hard to Get off there wall. I'll see if I can do it without damage. Thanks for the good suggestion.
