2022 Discovery LXE 36 HQ Battery Cutoff
RoadieT
Need some help in cutting off house and chassis batteries when storing coach. Manual mentions a battery cutoff at the driver's side rear compartment. I have located the inverter cutoff, the charge controller cutoff, and the two switches in the entry footwell. Are there others? Is there a preferred arrangement of these switches to prevent battery drain?
Thanks
Remove the negative battery cable from the battery if you can not find the cutoff.
