2022 Minnie 2529RG Galley Drain Valve - Valterra replacement
epnh
Winnebago
Minnie 2529RG
Can someone give me the correct part number for the Valterra replacement for the Lasalle Bristol 66N4AB72GM galley drain valve on the 2022 Minnie 2529RG?
I have asked around and researched the net and asked ChatGPT and Google AI and as usual I have gotten three different Valterra part numbers matching parts that are very different from one another.
I asked Winnebago Customer Service and they disavow using anything other than the original Lasalle Bristol part.
If you have actually done the swap on a 2529RG and can tell me the exact part number you used, that would be ideal.
Thanks...
Rick in NH
Not really, never did get any sort of reply here or on other forums. It appears the Valterra TC-372 is as close as I'm going to get. We'll see.
I wish I could find someone who has done this conversion, also am trying without success to get feedback on why that galley drain valve is so hard to operate. It takes both hands to get it to open and then closing it requires I be VERY CAREFUL in the extreme to avoid bending the shaft again. It shouldn't be that difficult.
Rick in NH
Thanks Rick. That helps. Have you already purchased the TC-372, or are you still trying to verify that it will work before ordering it?
Rick in NH
I bought one, hoping it will fit. It looks like it should. I'm holding off on installing it until the LaSalle that is in there now breaks which will probably happen any time now. I also need to find someone to put it in for me, I don't have the mobility, finger dexterity or eyesight to do it myself.
Rick (from NH, currently in TN)
I have installed new valves of both brands as a mobile tech that were "stiff' and there is no clear answer why. I have taken several back apart to check the blades are not being pinched, but no conclusion. I have to chock it up to really cheap cables. Also in Tenn.
Where in TN are you? I'm in Jackson county north of Cookeville. If you're still doing mobile tech stuff, we should get together. I'm definitely going to need someone to make the switch when (not if) the time comes.
Rick in NH/TN
I am just North of Chattanooga. Nice area where you are. Lots of campers and places for them. I have been up there several times purchasing things for my RV and travel. Native Mainer myself. Just took Route 2 across NH up and back for a visit in Maine.
Waiting may be an issue. It is always best to be able to drain the tank.
