2023 conquest 6237LE
Shick
I have a 2023 conquest 6237LE on a 2022 Chevy express 3500 just noticed when I open my cab doors they just hit the corner of the cab over but the further I open them the clearance is much better any have the same issues we don’t have alot of stuff stored up there thanks
It sounds like your cab doors are misaligned and hitting the corner of the cab over when first opened but clear as you open them further. Possible causes include:
1. Misaligned door hinges: Could be slightly out of alignment.
2. Body/frame flex: The motorhome’s body might shift, causing door fitment issues.
3. Weight distribution: Even if you don't have much stored, uneven weight could affect door clearance.
4. Binding seals or trim: Rubber seals or trim might be causing interference initially.
To resolve, check the door alignment, inspect for any binding seals or obstructions, and ensure the weight inside the vehicle is evenly distributed. If the issue persists, have an RV technician take a look.
Pictures are worth a thousand words!close up of problem, and overall area would be a start.
Pictures looking at the front so we can compare how both sides sit in relation to cab might be helpful!
Really you can't feed us with enough words to get a quality answer!
