Stuart W
- Nov 2, 2019
- Entegra
- Cornerstone
- FL
- Cummins
- Jeep Wrangler
100% Neal, agreed there are so many variables. One big one you brought up about fuel-fill rate and foam, on a 100 or 150 gallon tank a slant on the isle could equal a significant difference in volume. Earlier in this thread generator and Oasis fuel consumption came up, I believe the MPG calculations are simple tank float level fuel volume Divided by miles driven, so if your cranking 3 AC’s running the generator cruising down the road on. 100 degree day your MPG will suffer.@Joe Hogan I suggest performing this test. Diesel fuel, especially at the high rate of a truck pump can generate a lot of foam and easily throw off your mileage calculations.
Stop 1: At about 20 gals prior to full slow down your fill speed to about half. With around 10 gals remaining, slow it further. Goal is to minimize foam. Maybe even wait a minute or so and then try to get as much diesel in as possible to ensure a full tank.
Stop 2: Repeat above. Now measure your mileage. Report results.
My two 4369’s pretty much averaged 6.8 MPG but on a rare occasion when my route was mostly on the flat or downhill I saw 8.2 one time, by my next check it was 6.8.
