2024 Winnebago View dinette table
DDDever
Our dinette table top clicks as we go down the road. I have tighten the screw that adheres the top to the base but that doesn’t seem to help. Sometimes it actually makes it worse. Has anyone come across this and been able to fix it? The clicking drives my daughter crazy as we are traveling. Thanks!!!
Obnoxious, isn't it? The top of the table is not making the noise. It is applying lateral force to the post causing it to move slightly in the metal base that is screwed to the slide-in floor. At least that is what was causing it in our 24D. To verify it, take the top off of the post, lay it upside down on the cushions right behind the driver and see if it makes the noise with the table off of the post. That cured the problem for us. Grabbing the post with my hands and pushing it forward and backward produced the same sound.
Mudsock, thank you so much for your insight. I will do as you suggest. How were you able to secure the Post so it didn't cause the noise?
