2025 Revel 44E: How do I turn off the D/S Utility Light?
Scrooge.Ebeneezer
Hi folks,
Newbie here. I can't find the light switch for the exterior/driver-side utility light. It's an LED light that is about 6 inches in length. It's not above the fridge, or on the Nautilus in the back or on the light bar itself. I'm dumbfounded :confused: and would appreciate your help. Thanks!
From Gemini: It should be in the Main Firefly touchscreen/ main control panel. Tap the lights icon, then look for a button labeled, utility, service or docking. It may be tucked under an "Exterior" sub-menu within the lighting page.
There should be a manual override switch in the wet bay or on the dash to the left of the steering wheel.
The switch in the wet bay is so you can turn on the lights if working there at night.
Keep in mind, It may be motion sensitive.
