25FT expandable garden hose
  • Thread starter Thread starter Neal
  • Start date Start date
  • Featured
Administrator
Cummins 400 HP
I like to keep a compact/flexible hose in the wet bay and my last one decided to burst. Time for something new and hopefully better. So far this one feels better and I think it will do the trick. It complements my egg tray! :)
25 ft expandable garden hose
Okay! My questions and experience.
It's a garden hose (portable or not)?
How much flow to keep it from coiling?
How much restriction if pressure is not maintained?
To me these are serious questions based on My personal experience.
I thought a lay flat hose My brother dragged about was ideal, My thoughts were storage. But then I found it developed leaks in short measure. It kinked unless the path had enough radius.
Then I found one of the earlier models like you just posted. I do more than wash the rig with My hoses, and it fought me if I didn't waist water. I gave it away! I also found that when coiled the inside diameter was reduced and would lower flow rates.
My friend got a stainless reinforced 100 footer. You could stand on it, and it wouldn't collapse, nor would it kink.
My transfer pump flow was so slow I finally pulled out My 5/8 hose and completed the job. He asked if I wanted the hose. You know My answer.
The white hookup hoses don't like to be coiled on cold mornings and that's when I go get water.
Now a hose that is drinking water safe is on the market that withstands the cold without cracking, and large enough diameter to do the job. I have two of them. One light green, and one light blue.
But I'm still looking for one that takes less space!
Interested to see how long it lasts. I bought the Pocket Hose and the outer lining at just behind the connection point tore on the first use. I switched to the Zero Gravity hoses, and have been very happy, so far.
This is a light duty hose intended only for wet bay rinsing and black tank flushing.
Keep us informed please.
I have a drinking water safe Zero-G hose (from Lowe's) for our primary water hookup and a non-shrinking, but light-weight, but sturdy and very flexible hose for my black tank flush. I've been using both for several years now and am 100% satisfied with both.
Yes, keep us informed about the new one.
Have used zero g for years and they have held up quite well even sitting outside in the FL sun.
I have a similar hose that is made for potable water just like my white hose. I have had it for 4 years and love it. I only use it for filling my tanks or water hookup at my site.
Preface to say we never use our tank water for any ingestion! We carry bottled water for that.
I carry one hose, a white one coiled up. I use it for anything requiring water from a spigot.
That includes rinsing the 'stinky slinky', but the hose NEVER touches it, just spraying water down the end!
I see no reason to have any more than one hose to do all duties.
