Russellvh
- Nov 18, 2021
- Home based out of the Colony, Texas
- Forest River
- Wildcat Fifth-wheel
- 2019 Ford F-250.
- Yes
You’ll have righty a third ish of the power. You’ll use an adaptor and manage your loads accordingly. Not a big deal. Just have to be smart about it. Worst that happens you blow the pedestal breaker and start over.You'll have to manage the electrical loads as obviously you'll only have half the power.
This might be useful
A 50 amp 240 V service is 12.0KW while a 30 amp 120 V service is 3.6KW. If one uses a 50A to 30A adapter, then only 3.6KW is available based on the rating of the adapter. On the other hand, if one uses a 30 A to 50 A adapter, then again only 3.6KW is available based on the rating of the adapter. If your RV has provision for two 30 A service cords, the advantage is to use 50 A to two 30 A adapters for 7.2KW of power. The formula is VOLTS times AMP equal WATTS. E x I = PIf you don't have a "dog bone" you need to get one. It's available at most RV stores, Walmart and Amazon. It's just something you'll need to keep in the RV.
Major thing to remember is a "50AMP" RV has 2 50amp power lines coming into it for a grand total of 100amps. A "30AMP" RV has 1 power line with 30amps grand total so there is a big difference in how much power is available.
30 Amp Male to 50 Amp Female Dogbone
Amazon Dog Bone
Not exactly true. The maximum current from a 50A service is 50 amps. Yes, you have two 50 A lines but still, the maximum current is 50 amps. A 50 A service measured to neutral is 120 volts or 6000 watts. E x I = PIf you don't have a "dog bone" you need to get one. It's available at most RV stores, Walmart and Amazon. It's just something you'll need to keep in the RV.
Amazon Dog Bone
Maybe, just maybe most people do not have an extensive background in electricity.YES it is rather simple and I don't know why some folks don't grasp it, no offense intended.
Maybe it's the out of phase business that throws folks
Not true. ^^^^^If you don't have a "dog bone" you need to get one. It's available at most RV stores, Walmart and Amazon. It's just something you'll need to keep in the RV.
Amazon Dog Bone
