7 way plug tester
Oldman53
Lincolnton, NC
Cruiser Twilight Signature
tws 2580
30 ft.
I was looking for a 7 way trailer plug tester. What was sent to m was a 7 way flat pin female plug tester that plugs in to my tow vehicle. I am looking for a male 7 way trailer flat pin tester that plugs into the trailer wire female plug, to make sure the female plug from the trailer is wired right.
The male plug on the tow vehicle is wired right. Just checking the trailer female plug.
Assume you mean 7 pin.
If the vehicle is wired right then plugging the trailer and doing a visual will confirm trailer wiring.
On the flip side. If you vehicle I wired wrong you will need to decide what vehicle you choose to make the standard.
I personally would choose to leave the tow vehicles wiring alone unless the wiring was a rat's nest.
I have done it both ways.
