92D190V Electrical Questions
Digger Dawg
Barton Community, George County, Mississippi
Dodge Ram 350
Roadtrek 190 versatile
18'9"
Dodge B350 Maxivan 1-ton
6.2L/318 CID EFI gas V8
1. Can you just swap out the FLA coach battery for an AGM one?
2. Requesting recommendations on whether I should just upgrade the Magnetic 32 Amp Power Converter/Charger Series 6300A with the PD4635 with remote or Boondocker 1245PC from the BestConverter website?
3. Requesting recommendations on a replacement or upgrades for my PowerLine Model #22-1 Battery Isolator. Also, is it safe to drive the roadtrek with this removed and the coach battery disconnected or removed?
This lady is basically all stock with a new antique tag and I am doing my best to get her road ready for some long hauls. I would like to run her down to 'Goula or Biloxi for Cruising the Coast but may have to wait until next year.
AGMs should never be equalized. They have a maximum charge voltage that should never be exceeded. RV converters (3stage) have AGM settings. Make sure you use them. The brand is not important on your converter choice, it should be 3/4stage for the most efficiency.
No! Disconnected isolator will not be an issue.
