92D190V Electrical Questions
OK, I finally found the remains of a probable fuse housing and a similar 6 ga red wire with an identical rusted bolt on it. It runs back under the RT and I'm thinking that it goes to the coach/house battery. Can someone confirm for me my assumptions (yeah, I know) on how the isolator is wired?
A1 - from the Alternator
B1 - to the vehicle Starting Battery
B2 - to the Coach/House Battery
Also, does this need to be connected for the alternator to charge the batteries? I ask because my brand new Starting Battery now needs charging. Lastly, what size fuses should I use? 150Amp? I believe the alternator on this is 120 or 130 Amps.
Lots of questions!
Pictures help when asking how to hook things up.
More likely, the column linkage needs adjustment. That should fix the starting problem.
I assume you have an inverter. That is where a 150 amp fuse would be used.
#6 wire should be fine for the converter hook up.
200w is! Well 500 would be better.
DC to DC converter is overkill. Like I said. A diode will be all you should need. Many isolators are just that. A diode circuit.
I know you asked more questions, but it's time for sleep.
Now that I've found the other end of missing fuse connection, I'm gonna check out the isolator I have to see if it is any good and reinstall/replace it. I found a mechanic with a passion for old cars & trucks to help me give this beast a thorough check to see what all needs attention before I put her on the road for any long haul. Yep, more solar would be better and I may see about adding some portable panels to the 200W I'll be putting on the roof.
OK, after going through the roadtrek electrical diagram notes that the awesome Mr. John Slaughter did http://www.metrotrekkers.org/utility/electrical.htm, I found out that those rusted out or broken little boxes are actually thermal circuit breakers and that they are usually either 30A or 50A. I believe that the two in the coach battery line from the isolator are 50A so that is what I ordered. Today, I'm gonna try and test the isolator just to see if it still works.
