Bought a unit that didn't have the 50amp/2AC option. Is there a reasonable (affordable) way to add a second AC? I know 30-amp isn't enough. The model is an Apex Ultralite 256bhs if that matters. Thanks
RV a/c units are notorious as energy hogs. Have you considered a mini split? I would consider checking power use on both units to make a decision. The splits have a fairly high SEER rating, use inverter techniques lowering start current, and throttle rpm of compressor to regulate cooling.
