Air bag/TV question
labill
Hot Spring County, Malvern, Arkansas
Bay Star 2901
29'
Ford F53
V-10
I purchased a used 2012 Newmar Bay Star motorhome last year. This is my first motorhome and have two questions.
1. My front air bags don't want to hold air pressure and drops from 80 to about 40 psi. Is this normal?
2. The TV shuts off when the ignition is turned on. I am assuming this is a safety feature, am I right?
Any suggestions, answers is appreciated.
labill
labill
Welcome aboard. I can't help you with your air bag question but I can assure you that your TV (s) will shut down as soon as you turn your ignition switch on. No watching movies while you drive. ;)
Didn’t realize Bay Star had air bags. I thought that was only on diesels…
Check the Schrader valves where you fill them. if they auto fill with a compressor, check the fittings with soapy water.
lots of questions. Do you have an onboard air supply? Do you have a ride leveling valve? Once it goes to 40psi does it settle in there and stay? Do you put air in supply tanks manually?
It appears these were installed by prior owner. They have to be filled manually. No ride level valve and no tanks.
Guess I have some modifications to do.
Thanks for the response.
labill
