Freightliner air tank drains
pdoug
Knoxville TN
New Aire
Freightliner
Cummins L9
How does one drain the air tanks on a Newmar New Aire Freightliner chassis?
Look in the front axle wheel wells for the pull lanyards.
You should have lanyards in both front wheel wells. Make sure you look for them when the coach is aired up as they can be tough to find. That way you'll be familiar when the coach is aired down. There is an oval in the frame rail on both sides the cables protrude from that oval. To make it even easier, use an old awning rod if you have one or make a rod, about 30" long with a hook on one end and a handle on the other.
