Air conditioning compressors won’t run
beanhedd
2026 DYNAQUEST XL 3200kd. Cannot get both a/c compressors to run. Fans run in manual low or high but not in auto. Switched power source from 50amp to generator a couple times. No help . No fault codes. Help
Yes it’s still under warranty,but if it’s a simple circuit breaker or such I can fix it.. I’m in the Okefenokee swamp right now sweating my ass off.
I had a similar problem with my Brinkley, but only one A/C unit…
Do you have the Firefly control or another similar CANbus control system?
Try a full system reset (complete power down and restart) of your computer control system.
Sounds like a thermostat issue
Kevin, you’re a hero. Thanks so much. Your solution solved the problem. We have been sweating for two days. My wife says thanks too. So simple. I will pass the good on.
Dan, sorry gave credit to the wrong guy.....Youre a hero.....it worked like magic......a/c blowing cold now, wife happy, so that makes everyone happy.....thanks alot....simple....im learning....
I sent mine to the dealership for two weeks to learn it… if that saved you some time, good deal.
