bpaikman
- Jun 25, 2020
- Lake Jackson, Texas
- Ventana LE 3436
- 35 feet
- Freightliner
- Cummins 340 hp
- 2013 Subaru Crosstrek - manual, flat tow
I don't know if any of you saw the posts I made while we were traveling through Colorado last month, but we observed the following:
1. hearing a "ch" sound every 30 seconds,
2. experiencing a porpoising effect (We manage to correct that problem by the way we handled the jacks, but it still was puzzling because it didn't do that doing our last 3000 mile trip.
3. When I drove the RV to its storage facility, my husband would follow to look for issues - and he was observing what he thought was a slight lean to one side and it seemed lower than usual toward the back.
4. We lost a rear SnapPad (fortunately under warrant) , probably on a bumpy, but carefully navigated, detour on CO 50 near Montrose. We think it's because the rear of the motorhome is riding a little bit lower than it should've been.
-----We believe found the issue. We took it in for service and they discovered a small leak in one of the rear airbags. interestingly, they told us it could still be driven as is, for some time .... uhhhh we opted to replace. And we are replacing both rear airbags at the same time.
Not a cheap repair, but it IS the first major-"ish" repair since we've had it.
Just thought this information might be interesting.
(W experienced the first symptom of this airbag leak, porpoising.... last year, 4000 miles ago, But we didn't realize what it was... we thought it was operator error. But we did wonder why we didn't experience it for the first 2500 miles).
(Porpoising, or rabbiting, as I call it, Is when the motorhome leaps and jerks forward like a porpoise, and you realize what it would be like without air bags. We corrected the issue by putting the jacks down and taking them up again. We observed that the air pressure has to be maintained above 75 psi before starting off, and preferably 122.5 psi, which it will reach within a few feet of travel.)
Every time we have a problem, which is probably just about every time we have a trip, we learn something new.
