Auto fill/ Manual fill
newmarokie
southern oklahoma
newmar
Dutch Star 4018
40'
Freightliner
450 hp Cummins
2017 Colorado, 2013 Dodge 1500 quad cab
I think I have said multiple times that I am slowly learning my Dutch Star. I have a list of questions:
If you don't activate autofill at the control center, does the coach pull water from the city line?
If you have the water pump on does it pull water from the tank irregardless of auto fill?
If you do activate autofill, does the coach pull from the onboard tank?
If you do activate autofill should your tank run over?
How does the topoff function?
On my ‘21, the coach will use city water when one of these conditions is met: 1) the water pump is off, 2) the water pump is on, but the city water pressure is at or above 60 psi. Autofill does not come into play either way. It only puts water in the tank.
See above.
Autofill only fills the tank.
No, it should cut off between 95% and 100%
Autofill kicks in when the tank level is at or below 50%. If it is above 50%, use top off to top off the tank.
Thanks Ed
