There is one issue with the lithium batteries they do not handle extreme cold very well. Otherwise a great choice.I think nowadays it is wise to go the LFP battery route.
Less weight and more capacity. And no worries having them sit for months.
Any lead acid battery can only use about 50% of its rated capacity without damaging it prematurely.
Not so with a LFP battery. You can get the full capacity out of it. . . if you need to.
And they don't require any maintenance. No corroded contacts, no water to replenish.
I have switched my batteries to AGM Absorption glass mat and I love them. I looked at Lithium however while great performers they one draw back is very cold. Lithium do not like extreme cold and should be removed is sitting in cold for long periods. There are Lithium batteries with built in technology to help this issue.I use a deep cycle lead acid battery and when not dry camping leave my trailer plugged in year round. Still batteries seem to have a short life. Are the more expensive batteries worth the price tag?
The 32 degree is a big number! Dendrites are formed charging below that temperature.The cold is not as big of an issue like people think. If the battery temp is below 32F just charge with 0.1C and below 14F charge with only 0.05C
And as Wemustrv mentioned, the battery and BMS manufacturers took this in consideration and most good LFP batteries have now a heating element inside.
I am using LFPs to power my office in case of the numerous power outages we have in FL and have also one in my 5th wheel.
