Chuggs
- Nov 3, 2019
- Ventana 4037
- 40’
- Jeep JKU
I’m under the assumption that the 12v load testing devices are suitable for determining if your starting battery is serviceable. It will apply a resistance and watch the voltage result. More to see if it has the cold cranking amps needed to run the starter for a short time.
Testing deep cycle 6v batteries would require a timed run down using a device which applies a known load and records the time to drain the battery to the mfg. spec. The alternative being a EIS type tester which applies a load and compares the characteristics of the voltage drop to known data to extrapolate the results.
I’m kinda hesitant to drain my battery to find out if it was good or not, I don’t think the test itself is a healthy thing to do to the battery???? I’m probably wrong. It still isn’t convenient. Cannot imagine the Hassle of taking two 6v batteries and performing tests...which might take a couple of days...and repeating for three more pairs. You could spend a week testing. Or find a service with an EIS tester... you still have to isolate the batteries for testing, but the test takes less than a minute.
