Bedroom Doors Removal.
Gizmo
RVF VIP
Kansas
Ventana LE
2020 Jeep Rubicon
I have a 2017 Ventana LE 4037 with double sliding doors going into the bedroom. Does anyone know how to remove these doors from the tracks? I need to repair the track on the bottom of the door.
Dennis
I wonder if they are just held in the top track by weight? Have you tried raising it up to see if can be raised off the track then off?
I tried that and doesn't seem to lift.
Can you look at it either via ladder or a dental type mirror? Figure out how it's secured in the rail?
There is is typically a push up/ pull down lock on the roller assembly that will allow you to pull up on the door/s to get the roller guides out of the track. You might have to loosen the assembly to allow the rollers to come out of the track if the rollers are adjusted to the point that they are hitting the top of track and not allowing the doors to come off.
