sanda
RVF Expert
- Mar 24, 2021
- Pueblo West, Co.
- Cougar
- 28'
Thanks for the posts. We started using the reflective aluminum car shades years ago. They did make a big difference. Besides the windows we also cover the vents and shower skylight. It did make a difference but now the unit doesn't put out cool air. Yesterday outside temp 100 and unit temp at outlet was 80. Everything in the unit is clean. Just looking for suggestions on a good replacement unit.First thing to do, before condemning the unit, is remove the cover and see if the coil area is dirty. If so clean it and see if that makes a difference. Also check for air leaks from the “sealed” (usually leaky) cold air area to the outside. Theres a thread here somewhere about this.
Also look at the rated RLA (amp draw) on the sticker on the unit and the test the amp draw while its running to make a comparison (see pic). I had one running at really low amperage and that indicated that the charge was gone so the compressor was spinning freely and thus not working hard enough to draw the rated amperage.
Its hard to find an AC contractor that will work on these but if you call around, or better yet if you know someone, have the charge checked as Bob suggests. If its low you can have it charged, but it means you have a leak, and those can be hard to find/correct.
If it‘s clean, sealed, and tests ok, as Bob suggests, cover all your windows when its hot out but also your shower skylight. That really makes a difference in our coach and it doesn't block the view. We had a 30’ Bay Star with one 15k btu AC and it was ok for most areas, but even working properly, it couldn’t keep up with the temps the South (Memphis, Louisianna, South Texas, etc) in August and Sept. Theres only so much the unit can do, especially in a marginally insulated RV.
