Best shock ride
Notsoaverageguy
Sandiego
Winnebago
Intent
F53
V10
So I have the smallest A Class Winnebago called Intent. I already did the F-53 cheap fix on the sway bars nice improvement, but now I am going after the ride. The stock shocks just pound the home on the freeway cracks and any impurities in the road. I am not expecting Lincoln performance but I do have experience with suspension enough to know it can be better. Done a little research and a lot of people just bolt on Koni and while it stops the rolling (which I am actually ok with now) the reviews claim a rough as ride with the stock on the bumps. My RV is short and light when it comes to A Class and I feel like I can get away with a shock with less compression dampening. Any recommendations?
Not saying different shocks might improve your ride but also tire pressure comes into play. When I took possession of my present coach, the previous owner had the tires at 100 PSI. Dropping them down to 90 made a world of a difference.
Likewise; My E450 chassis calls for 75F 80R. I lowered to 70F 75R. Much better ride!
FWIW, I still have Ford's stock shocks, steering dampener, and springs.
I can control the coach easilt with one hand, and, although it drives like a truck....it IS a truck and always will be a truck that also is a large windsail on wheels!
our e450 class c. add konsway bars front and rear using roadster bars from E-Trailer. major ride change
Thanks for those tips, the sticker says 80psi I already set them to 75psi and I to have no problems with the control after the CHF fix. Been trying to do research on compression dampening as I feel that is what I am feeling through the coach. Again not expecting a Lincoln ride but think it can be better that a trash truck. It is worthy to note that twin tube shocks do not have a nitrogen charge which allow them to give a better initial response to the bumps. Sach’s is what is on my rig now and I have talked to ZF costumer service for specs and am waiting to see what they say.
Softening the shocks will also reduce body control and increase the rate of sway and lean. It is all compromise. The impact "jolt" that feel on road impacts is more the result of the impact hitting the suspension mounting points. Your CHF also slightly increased the impact transfer through the say bar. Reducing tire pressure also reduces handling response, fuel economy, and more importantly tire life. Most handling improvement add ons are somewhere between incremental and imaginary. The real enemy for ride is the weak body structure. Every hit lifts and flexes that corner and you feel that right in the seat.
Yes after more research and taking to a Koni tech who says the RSD is exactly what I am looking for. He stated the shock is NOT about a strong compression set up ( verified its twin tube not gas pressurized) and has a strong rebound and compression will build after the initial hit. Funny that is exactly how I would build a shock if I was to start from scratch, trying to address such a small motorhome. And 2 I need to buy or make the sway bar struts from the CHF that will set the sway bar back to the 90% angle it was before I moved it to the inner hole that I understand.
