Rod St John
- Nov 28, 2020
Hello Folks, I'm hoping someone might have encountered this issue before and can help guide me where to start looking for the issue.
I have my 2012 Coachman Leprechaun (32 foot) Ford body parked for the winter. It has been winterized, etc for approx a month beside my garage. Last night, I was coming home and saw that some red lights were on.. turns out that the brake lights on the RV were on ! My first thought was that the brake pedal had been pressed somehow, or hadn't come fully up, however, that was not the case. I then pulled the button switch off the pedal mount and pushed it all the way in by hand. I was fully expecting that the lights would go out, however, no dice !! The brake lights stayed on. I ended up disconnecting the battery so it didn't go dead.
Anyway.. has anyone experienced this issue ?? My thought is that perhaps the plunger switch is bad, but thought that I would check with you experts before I start replacing parts.
Any help or guidance would be greatly appreciated !! FYI - The RV is original and I have not had any previous lighting or wiring issues before this.
Regards,
Rod
Regards,
Rod
