BGMAC
RVF 1K Club
- Jan 28, 2020
- Cypress Inn, TN
- Forest River
- Georgetown XL M-369DS
- 37ft
- F53
- Titan V10
- 2024 Chevy Colorado
With a tight fit and more than 2 screws holding it in it should hold. I would have a screw on each side of the cross member. I would also use l brackets to hold the front cross member to the side studs.As it turns out, I can't actually remove the plywood myself. I was however able to get a couple shots of the frame, I may end up calling my moms handy man cousin to see if he can help get it reassembled. I find it rather disturbing that Forest River slapped a pretty high weight limit on these bunks but only secured them to the walls with two screws on each corner and built the frame from 2x3s. 50 thousand freaking dollars and this is what I get
