Question, if you swap out your tank filler for a larger one and use a high flow nozzle, will your tank vent keep up? Or will you be bathed in the ever so pleasant diesel shower?
JoeHogan, I would think the filler neck itself would be enough of a vent. With my truck I have to hold the nozzle up and not squeeze the handle any farther than about the first notch, but even at the 'low flow' for the nozzle it is probably four times faster than car sized nozzles at full flow.
TJ, I looked at the instructions that come with the TSD card (memory refresh). It says the first thing to do is go to the Commercial Truck Island, so if there are RV pumps there then you should be OK to use the card there and still receive the discount.
