Thirty (30) amps at 120 volts is 3600 watts.   You need to determine how many items you have turned on and not exceed 3600 watts or 30 amps.
Converter = 250 watts, Refrigerator on AC = 150 watts, Air Cond running = 1500 watts/starting 2160, Microwave = 1200 watts, .......this totals 3100 watts.   What else do you have on?   Coffee maker, heater, TV etc etc etc
The process is called "power management".    No, you can't run EVERYTHING at the same time.
If you only have a 30 amp service for the camper, then powering it from one side of a 50 amp service using a dogbone or adapter will exceed the power wiring of the camper.  This is not good!
If your camper is set up for 50 amps and you have a 50 amp to 30 amp dogbone or adapter, then you can easily overload the 30 amp breaker at the power post.    You should always use the 50 amp service and not the 30 amp service on the power post.
