Question Can I run my RV black/grey water hose under my RV for dumping?
tjayne
I have a 2020 Jayco Eagle travel trailer. Moving it to my own property tomorrow. Have septic and water hookup there. Would like to turn the camper toward Southern exposure for winter. This would mean the tank valve is on the opposite side of the camper than the septic. I have plenty of hose to reach the septic. If I can set it up for the right gravity flow of the black/gray water, would it be ok to run the hose under the camper for dumping? Don't know if the bend in the hose would be a problem?
I think you will be fine. Keep a fall on the hose and have enough hose to put a good curve in the hose to keep the flow as it goes under.
Not a problem.
Done it numerous times. Never a problem.
