New fear unlocked…thanks for that.I don’t trust people enough to use it. It makes it too easy for some mischievous person to drain off oil, without one’s knowledge. I know, it is unlikely, but for me, not worth the risk.
Really!? How many people are going to crawl under your vehicle to see of they can drain your oil? Get real.I don’t trust people enough to use it. It makes it too easy for some mischievous person to drain off oil, without one’s knowledge. I know, it is unlikely, but for me, not worth the risk.
The problem being the last bit of oil is where the contaminants will settle. They will not be flushed out with a bit of fresh oil but they will get stirred up when the engine is running.Summary of internet comments
Residual Oil After Drain
The Fumoto Engine Oil Drain Valve, once installed, leaves a small amount of residual oil in the engine oil pan after an oil change. According to discussions on various forums, the residual oil left by the Fumoto valve is typically less than half a quart, which is around 2% of the total oil capacity in many vehicles Some users have reported that the valve extends approximately 1/8" to 3/16" into the oil pan, which is not enough to prevent the oil from draining properly and bringing out debris However, concerns have been raised about the valve potentially leaving a small amount of oil in the pan, which could mix with new oil during the next oil change Users have suggested that this residual oil is not a significant issue and can be managed by adding a small amount of clean oil after the drain to help flush out any remaining contaminants
Get up in the hood. Sugar in gas tanks, latest is cutting catalytic converters. There is lots of evil out there, lots of hate for people who look prosperous. Hope your perspective is correct, but I take no chances.Really!? How many people are going to crawl under your vehicle to see of they can drain your oil? Get real.![]()
