YouTube Chill Cube on 2000 w Inverter
388Racing
Massachusetts
Sunset Park RV
Sunlite 21TH
Lippert
I have a LiTime 2000 watt inverter and two LiTime 100aH Batteries that can run my Furrion Chill Cube for up to 3 hrs. I also have many other upgrade videos on the channel.
I would not be recommending that solution. Not good engineering from the battery and inverter to load combination.
Maybe I should have explained a bit further. I am only using it on the inverter to cool off the camper a bit then turn it off, and only when I need to stop at a rest area to catch a couple of hours of sleep. I am not trying to use it full time like a boon docker.
