Cooked water heater...
JFlo
Recently, my water levels got low while the water heater was on (using propane, not electricity) and black soot came out of the water heater external exhaust, along with a burning smell. Anyone know what might have burnt, and what I might need to check?
And low water will not make black smoke......That is something blocking the airflow in the burner tube and getting a real yellow flame.
I should clarify by burner tube I mean the curved tube just after the gas valve.....
I have seen a puff of wind put the flame in the venturi and cause a temporary situation, but not permanent.
Thanks everyone for the replies... I looked in the burner tube inlet and there were some cooked stinkbug remains. I removed them and blew some compressed air through the burner tube to clear it out. I then added some water and fired up the propane heat and the flame is in fact yellow/orange. I'll need to investigate the actual burner tube (thanks @TheLooks for that info).
At the time, I thought perhaps the water level being low may have been the cause, but I now know that wouldn't be the case. Thanks again everyone... I'll report back on this thread once I can troubleshoot more this week.
