Cutting boards separating from induction cooktop covers
Not open for further replies.
Staff member
RVF Administrator
Anyone else having issues with the cutting boards working their way out? I reported this to Newmar under warranty, they removed and reglued them. It happened again about a year ago, I removed and reglued them (with silicone). Now again one wants out. Wonder if I should go to epoxy next time around?
Honestly, I would consider that a feature, not a bug. I would stick with the silicone that way if I ever wanted to replace the cutting boards, I could get them out. Go with an epoxy and you’ll probably break the covers before you separate the cutting board from them. Cutting boards develop scars and stains over time, so I find it nice to be able to replace them. @Dutch Star Don had a pretty sweet mod over on iRV2 where he ordered a custom sized cutting board perfectly cover the induction.
100% agree on the ability to replace them if needed. Wish there was a better way to prevent what I've been experiencing.
Maybe some 3M tape? If you don’t go too overboard with the tape and you hold the cover face down in a flat surface when prying to remove the board, i’d bet it would come out.
We actually don’t even use ours. We just have these flimsy cutting mats that we use.
You could also try some spray adhesive or a some small dabs of liquid nails in the corner. I’d not use much though. Better that it comes out a little too easy than never at all.
Our MADP didn't come with cutting boards attached to the countertop; and, I'm glad it didn't. We just carry a couple of loose cutting boards. That way, they can be easily changed out. And, cutting boards should be replaced when the surface gets rough as it makes it hard to get them properly clean.
I carry 2 regular whitish cutting boards...they do double duty as a lap tray or desk if we‘re eating on the sofa.
I would use clear silicone sparingly several thin lines and a thin border approx 1/2 inch from the edge, sit something heavy on it while drying.
Yep, this has been done twice, once by Newmar and then by me a few months ago. Rectangle of silicone along the outside maybe 1/2 inch to an inch in from the edge then zig zag the middle. Both of my covers are doing this on one corner, odd!
Is it possible that one surface is warped, this isn't something that I have seen happen before.
Good idea, it may be worthwhile to just replace the cutting board inserts. I wonder how much Newmar parts wants for that? I'll inquire to entertain myself :)
I think your problem is warping that lifts a corner or end off the countertop. I'm told that thicker (1/2" or more) cutting boards will not warp as much...or, at all. Also, there are different grades of polyethylene plastic used in cutting boards. The high-density polyethylene material is supposed to be more dimensionally stable and cutting boards made from it are not supposed to warp, especially if they are at least 1/2" thick.
My chef source says that washing cutting boards in a dishwasher will cause them to warp because they are exposed to high temperatures for an extended period of time. While washing a cutting board with hot water is a recommended practice, exposing it to heat for more than a brief period (like had washing) will cause warping.
I like the bamboo cutting board, @Neal; looks like a good solution. For those looking for high-end cutting boards, check out the Epicurean line:
Amazon.com: epicurean cutting boards
