Resolved Dash heat
Larry Woodward
2017 Dutch star. Not getting warm air in dash heat with engine running. AC works fine but just air when running heater. Dialed all the way hot.
Sounds like the blend air door is stuck closed. Not sure if it's vacuum operated or electric on your Coach but that's where I'd start. This is assuming you have plenty of coolant in the system and no holes in your heater hoses.
Ended up being the water valve they allows the coolant to flow through heater hose. Had replaced after got home. Thanks for your reply.
Glad you found it!
