Dehumidifier working?
Russellvh
Forest River
Wildcat Fifth-wheel
2019 Ford F-250.
Yes
I have a counter top dehumidifier. We have had it about 3 years. For the first couple of years it seemed to work great. Each morning I would check it and there would be about a cup of water in the tank. Lately over night I’m only getting a couple of spoon fulls.
The lights and motor are running normal. Is there a way to test it’s working properly?
Get a hygrometer. There may not be much moisture to remove. Where I am now, the inside humidity is only 34%, so I turned off the dehumidifiers.
Thanks for the hygrometer recommendation. Texas summer. Humidity is 70% and up.
Most small dehumidifiers are thermoelectric (no compressor) and rely largely on temperature differential. Humidity levels in N. Texas are hovering @ ~40% right now, making it difficult for a non-compressor type dehumidifier to do a lot of good, especially if the inside temps are kept low.
Be sure to look at the coils (fins) to make sure they are not blocked with dust. The coils get wet and dust will accumulate and block air. Just like your AC units.
