DI rinse systems
They are now offering a clack head option. Not when I last ordered.
Redbaron,
What started all this for me was to upgrade a tank to the Clack head and bypass valve. I have found the WS1 V3006 bypass valve for $34 and the C-series C1190 in/out head for $24 at Fresh Water systems. Is this a good price or is there somewhere better to purchase these parts? It sounds like you have already done what I am attempting to do. Is there anything else I would need to convert my tank? I was hoping to find someplace local to purchase from so I could eliminate the shipping cost. Any ideas or help?
Thanks
Here is the parts list I made when doing the purchase back in August of 2022. I was building a large system for the house, and several smaller systems for horse trailers and RV's.
For the smaller system, I started purchasing the Tank from DIRINSE.COM for the DI-Pro-50. I then later purchase one from RV Water Filter store. These hold 0.5 CU ft of resin, and are perfect for the RV wash. I now have 2 units for my LA, one for DI rinse, and one for Soft Water.
Clack Bypass Valve
V3006
$29.95
Clack Bypass Valve | V3006
3
Clack In/Out Head
C1190
24.03
C-Series C1190 In/Out Head w/ Vent Trap
3
Clack NPT Elbow
WS1 V3007
14.95 (Pack of 2)
Clack 1 MPT Elbow Connectors | uswatersystems.com
3
Fine Mesh Upper Basket
FP-UPBSKT-FM
12.00
Fine Mesh Upper Basket for Many Fleck, Clack, and Autotrol Valves - Fits 1.05" Distributor Tubes
3
Riser Tube & Fine mesh lower Basket
BRT-1050-54FM
29.00
Distributor Riser Tube w/ Fine Mesh Basket - 1.05-inch x 54-inch
3
8x18 Media Tank (.44 CUFT)
PT0818-C
78
https://www.water-softeners-filters...31835-poly-glass-vessel-media-tank-w-base.php
Pentair 9x18 Media Tank
CH30317
106.00
Pure Aqua Inc (pureaqua.com)
Mixed bed Resin
1 CU FT
195.00
DI Resin Bulk | Order in Bulk Mixed Bed DI Resin for Sale for Water Treatment Equipment at Serv-A-Pure
2
DI Resen - Mixed Bed New
1 CU FT
215
Replacement DI Resin New mixed bed to deionize water for spot free car wash rinse.
DI Resin - Mixed Bed New - Direct Source
1 CU FT
195
8x44 Media Tank
PT0844
97
8" x 44" Pentair Structural 30305 Poly Glass Vessel Media Tank w/ Base (Charcoal)
2
Redbaron,
Again, that is great and complete information. I have an existing tank so I dont require all the parts listed. I am trying to replace the head of the tank with the C1190 and the V3006 bypass valve and the V3007 90 degree fittings, I will add a PVC 1" X 3/4" slip by thread fitting to these fittings. I also have a D1203 upper fine screen and hope it fits the C1190 head, the upper screen is the twist on type screen and it accepts a 1.05" distributor tube just not sure the twist on is the same on both heads. It looks the same, do you know if the screen fits the C1190 head? As for the balance of the parts looks like the pricing is pretty close. Either way I would still have to pay shipping, so I am thinking of just purchasing everything from Fresh Water Systems. Please let me know if you think the twist on upper screen will fit the C1190?
Thanks again,
I have several screens that all fit easily on the c1190. I think the size is standard, based on the opening.
