the_fu
- Dec 2, 2021
- Gilroy, CA
- New Aire 3543
- Freightliner
- BMF
- MINI Cooper S
I chose the cutting board material as it is stronger and less brittle than the ABS that is used by Newmar - but more importantly, for the average owner, this is material that is easily and affordably obtained. Might not be the most ideal, but it gets the job done.I have one question: why use the same material? Already it has proven that it will break soon or later.
There are more durable materials like Delrin, G-10 fiberglass reinforced board, or maybe even Nylon board?
The amount of work is more or less the same.
Newmar chose this material considering price and ease to cut. Just thinc’n
100% spot on. The doors are set to close too tightly from the factory IMO. It is a balance though as if they are not tight enough, the seal will not work properly and dust can enter the compartments. On my list is another video showing an easier way to adjust the strikers to get a proper fit. What really should have happened, however, is that the factory should have made these guides out of aluminum. It would not have cost that much to do that and they would work forever. They charge almost $50 a piece for those things now - that is criminal - especially given how easily they break.They break because doors are not properly aligned and they are taking too much of a hit.
No door should ever require a slam, full swing or lots of force.
That was very true on my 2013. My 2019 had a very small difference, but was not as drastic.I've found the door alignment changes between on suspension, dumped, or on a not level surface. Hard to properly align a door when the hole keeps changing.
I think this is the very reason for these plastic guides. Frame can flex just enough that they need guidance to properly engage the latch. Once adjusted when at drive height, then the door is opened and closed with jacks out and does not quite align. That said, this kind of alignment is in the Z axis. The breakage is mostly occurring, I believe, because the Y axis (in out) adjustment is wrong and when the door is slammed, the latch bar bottoms out and strikes the back (weakest part) of the guide and snaps it off. In addition to proper adjustment in that direction, I am also going to test out moving the back that section of the guide such that it cannot bottom out. I think the latch can take that on better than the plastic for when/if the door becomes misaligned down the road.I've found the door alignment changes between on suspension, dumped, or on a not level surface. Hard to properly align a door when the hole keeps changing.
Ironically the "barn doors" for my bays are the easiest to close and seem aligned.That was very true on my 2013. My 2019 had a very small difference, but was not as drastic.
It was the bay doors in the middle of the coach. It just happened that these where the large pass thru bays
