Dynaquest shower hot water not hat
bhullinger
Hey y'all. I have a 2022 Dynaquest. The hot water in the kitchen and vanity is excellent but I can't get the shower to get hotter than Luke warm. Is there a setting someplace? ThNk you!
Has it ever been hotter?
If I remember correctly, there is a mixing valve behind the shower control that is adjustable - could be that.
Hopefully an owner will chime in with other items to check.
I had a similar problem with my 22 5 series. I solved mine by putting the switch on the hotwater on demand unit to bottom position which keeps the hot water in the unit always hot. It uses more propane but less water and shower water is super hot
No idea what type of shower valve you have, but with most residential shower faucets it is one of 2 things (assuming it is a single lever type valve). 1) If your valve has stops on each of the inlets, the sometimes have calcification, some other type of blockage, or just partially closed. 2) inside the shower valve there are plastic gears and stops. These set the max water temperature. Sometimes they are shipped from the factory set too low.
