Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
same with our Newmar, and it's 8 yrs oldOn my Fleetwood Discovery, the dumping of the airbags was separate from lowering the jacks and when you dump the air both gauges will go to zero then you deploy the jacks. The Discovery had Freightliner chassis. The new Newmar will sit in storage for weeks before the air pressure drops on the gauges.
VERY interesting- we'll be also measuring with a yardstick - departure, and arrival.... when we move to new campground just a few miles away on SundayI just went out to storage to check my Newmar Ventana DP coach and this is what I found.
I went out to the storage area and check the air pressure it was sitting at 10 psi and measured the front wheel wells and they were at 37.75 inches from the ground. The coach has been sitting since the end of July without starting the engine or having the jacks deployed or dumping the airbags
I started the coach and let the pressure build to 120 PSI and remeasured the wheel wells and now they are at 41.0 inches.
Hit the auto level then aborted and the air pressure gauge stayed at 120 PSI and the wheel well measurement went to 39.5 inches
Turned off the engine and pump the brakes till the air pressure went to 20 PSI and the wheel well measurement went to 38.0 inches.
I'm not saying this is the way supposed to respond I saying this is what my Newmar does.
not sureDoes pumping your brakes affect your air bag inflation?
That sounds like it would work in a similar way on ours, but why would Newmar design it this way...I'm not 100% sure which way, but I recall my auto working differently depending on which selection the key was in, run or acc. One of the two would allow the auto button to release the air in the bags. I am in the habit now of hitting auto, then stop and let the bags deflate for a bit then restart. It seemed like the jacks would drop immediately and bags not fully deflate, thus causing the rig to sit a lit higher than it could. The start stop method allows me to get it dropped completely before I level. Your coach may operate differently, but worth a try on the key position....I came upon it by accident on mine.
Yeah, My thoughts exactly. It would also be nice if it was explained in the manual, but all mine says if I am recalling it right is that leveling requires key on in either position. Just the fun of RV life I suppose!That sounds like it would work in a similar way on ours, but why would Newmar design it this way...
Yup, my process exactly.@bpaikman Yes, my Equalizer automatically dumps the bags upon cycle initiation.
I'd like to put a muffler on my Ventana LE air bag exhaust, it is so loud. My leveler (Equalizer) dumps the bags when an auto cycle is initiated. I then hit another button to abort the auto cycle but allow the air release to complete. Once I feel the suspension settle into it's low position I then manually level the coach with the jacks. Lower each pair to touchdown, then adjust as needed to level. I do not like the auto cycle. End result is always too high.
Please do! You could see the coach going tower every time you pump the brakes and lowered the pressure in the tank. Maybe I have a stuck valve or something. I know my Discovery seemed to go a lot lower than my Newmar and they are both freightliner chassis.VERY interesting- we'll be also measuring with a yardstick - departure, and arrival.... when we move to new campground just a few miles away on Sunday
