Greg074
- Sep 19, 2022
- Central Illinois
- Coachmen
- Aurora
- 35 Ft.
- F53 Stripped chasis
- Triton v-10 6.8L gas
Thanks for the info, I'll give him a call. I have plenty of pictures so I will get those to him as well. Thanks again.Call up "Tim" at "ACKITS.com" with your request for mobile air parts. Be prepared to provide measurements, refrigerant type, pictures and descriptions of the port connection fittings because he might only be able to get you a new evaporator that is close but not an exact replacement for your original evaporator.
Rick
Ford Part number is YK229
I thought so also but no, that core is not the core used in the 2005 Coachmen Aurora. The fittings are wrong and the mounting bracket is missing. The core that was used seems to have been manufactured specifically for coachmen. Thanks for the help though. I really appreciate it.Ford Part number is YK229
That’s what I am finding out. Coachmen doesn’t have any info for anything prior to 2009. Guess we don’t matter that much to them.If it was made specifically for Coachmen then you may be out of luck unless you can find someone to make one for you.
Found a welder that said he can weld the connections back onto the core so we will see. He did say that because of it being a pretty delicate job, there is a possibility of getting some pin holes so we will keep our fingers crossed. Thanks for all the help.I don't think its so much Coachmen as it is Forest River the now Parent Company. They may have just gotten rid of that information. I did see a lot of 05 Aurora's still for sale. You may be able to contact the that dealer or owner to see what they say. Good Luck I hope you find something.
