Fifth wheel
cgeszvain
does anyone have experience with the Curt A20 or A16 fifth wheel?
I am contemplating buying one or the other for a short box Chevy. The Curt website says they are for long boxes only.
The problem with short box without sliding hitch is you can forget and really damage the cab in tight locations.
So then the fifth wheel should be set as far back as possible ? What is the advantage of moving it forward?
Thanks
My understanding is that the hitch should be set directly over the rear axle. In a short box truck, that may not give you enough room to make sharp turns without the front of the trailer hitting the rear window of the truck.
Thanks
As was said, over the axle is best. This balances the load in the bed. Moving the hitch back in the bed can lead to lurching, and will unload the front axle that may lead to some handling issues.
I have a 6.5 ft bed. Reese gave a dimension for the rails. It is a little close for my liking. However sliding hitch is a problem for me. If I can forget and turn to tight, then I can forget to slide the hitch back! When I mounted the hitch I measured clearance twice then positioned truck under the rig to verify I would not be popping the truck window out in a tight spot. I am about 2" behind the axle, and live with it.
thanks
I think if you looked at the Anderson with you will be surprised. After mounting, the ball is towards the tail gate but the weight is still over the axle. The height has three different settings, Gives plenty of room for the bed rails.
AND,,,,,it only weights 35# but has a tow weight rating of 24,000#.
Draw what you see. Then think that opinion through!!!!
My Dad has a pull rite auto slide. Works great. It's on his shop floor because he went Class A. Wish you were in Oregon!
Kevin,
The Anderson hitch has an off set to the rear of forward, you choose. I've got mine toward the rear of the bed. It is off set about 3-4 inches. (not sure as I have never measured it.). The weight is applied over the axle. I can draw it but the weight still is applied over the axle as that is where the adaptor for the king pin connects to the hitch. When you slide a slider aft, where is the weight? Never used one but it is one solid piece and you in fact are moving the weight aft also, isn't that right? WIth the Anderson, the weight on the truck bed is not moved, just the attaching point to the hitch.
a Pullrite auto slider moves the pin box backwards as you turn pushing the front of the 5ver backwards away from the truck cab and then forward to the original position as you straighten up. The movement happens only when there is an angle between the truck and trailer which as a general rule only happens at large angles at slower speeds. The amount of movement increases as the angle increases and vice versa. A manual sliding hitch has to be manually released and slid as you need in order to make a sharp turn and must be slid back and locked afterwards. Many 5vers are shaped to minimize this problem and some people have used 6.5ft beds with a regular hitch and just been careful when turning near 90 degrees. Some hitches such as the Anderson move the mount backwards a few inches and generally only work with a ball mount. A friend of mine is using an A-16 mounted on rails a few inches back of the axle and does not have any problems with that setup. Most say that these things handle better when the pin weight is directly over the axle. I am using an A-20 in a factory puck system which works well but I have an 8 ft bed.
