Finally got a forced regen completed
newmarokie
southern oklahoma
newmar
Dutch Star 4018
40'
Freightliner
450 hp Cummins
2017 Colorado, 2013 Dodge 1500 quad cab
I bought a diesel laptops handheld shortly after I got my coach in October 2023. I have never been able to complete a forced regen with. I have opened support tickets twice to get help. They want to do a software update to see if that is the problem. It never is. I finally broke down and bought the Zurich heavy equipment scanner at Harbor Freight today. It has a members only price of $309 now until Christmas. I looks an awful lot like the Diesel Laptops handheld that is not being offered anymore. Same size, same buttons, same icons on the home screen, same flow tree of commands, and same font. Anyway, I plugged it in, went to DPF regen section, and it fired up and did a regeneration. .48% soot load. WooHoo!!
Interesting. I’ve done a regen with the Diesel laptops handheld and worked for me. I did do the firmware update prior to first use.
Nice to hear about the one from Harbor Freight - same one I picked up when we bought our coach.
Glad it worked out for you.
I see the diesel laptops handheld now has a version 2 out. The one I bought, which works for me, is now only $199. For anyone that doesn't have a scan tool and the ability to clear codes, force a regen, I suggest considering one of these and try it out, if it doesn't work for you, return it. 199 is a great deal what is normally 699.
But a lot of options out there but I highly recommend having something on board, that works. It already saved me once from a derate and tow.
Can you share a link as to what you got from HF so others know the one that works for you?
I hope this works. I have stated many times that I am quite illiterate IT/internet stuff.
There are a handful of prompts that are different, but I would still wager this is the original diesel laptops handheld.
Yes, the Zurich is the one I have as well.
Works well and, luckily, I have only had to use it in other coaches to verify what their warnings were.
New to the diesel pusher lane and I mustvsay, this regen deal is one of the most troubling things on my mind. I dobt get it. I've read where it happens as you drive and you may not even know it. Others have said you have to force it every so often. And it could happen while traveling and leave you stranded. So much to learn about this.b
David, I haven't had a derate (knocking on the biggest piece of ebony wood I can find), but I am always trying to be prepared. I built a defeat device to get me home or to a shop if I have a DEF head failure. And now I am more comfortable that if I have a DPF flow issue I can force a regen. Both of these things are insurance. We hope we never need them but are glad we have them when/if we do.
Saved me from a tow. Must have in my opinion. Need to not be afraid to use it and know how to use it. It was a bit frustrating for me when I was on the side of the road trying to figure it out.
Thank you. I'll add that information to my journal.
