First time winterizing -- how much pink stuff do i need?
breal14
New England
Four Winds by Thor
Chateau 24T sport
E450
V10 Triton
24' class C, pretty standard set up.
40-45 gallon tanks all around.
how much pink stuff should i buy to plan for winterization next month. 1 gallon? 4 gallons? 10 gallons? i have no idea what i need. Anyone have advice?
adding it to my october subscribe and save discount on amazon :D
Likely 3-4 gallons. I open low point drains, blow the lines out and keep the inside around 68 during the winter. Close the low point when blowing out the lines, do one at a time about 45 lbs pressure. I use a small heater inside. I don’t use the antifreeze in the lines, only in the drains. Just enough to fill the p trap. My drains should be good with the inside temp but just to be safe.
If you park it at home I would keep it warm inside during the winter.
40 foot class A. I also blow the water from the pipes using compressed air. I do that to reduce dilution. I then follow with "anti-freeze". With 1.5 baths and a clothes washer, I use 5 gallons.
FYI... RV "anti-freeze" does in fact freeze, but when it does, it does not swell-up to burst the pipes.
That's all I've ever done to include draining the water heater. Doing two rounds @ 30-35 psi, letting the lines pressure up then opening one valve at a time until only dry air is coming from the outlet. A few pints of RV antifreeze in each p-trap and it's all good.
Yes drain the water heater as well.
Amounts of antifreeze used can be from one to five gallons depending on RV size and preferred method and is once and done for the season. No need to subscribe and save.
Some people like to fill all water lines with antifreeze. You can do this with a bypass kit that installs on the inlet side of the 12v water pump so the antifreeze can be pumped dirctly from the jug to fill one line at a time. A helper is useful to let you know when antifreeze comes out of the taps. Once done, put about two cups of antifreeze into each P trap. Others use a hand pump (comes with fittings) to connect to each faucet to fill in the reverse direction.
I use compressed air, antifreeze in P traps and washing machine per Splendide instructions; about one gallon.
I use one gallon.
Here is my procedure:
Open all drains including the water heater and drain full system.
Close all the drains and replace low drain plug
Hook up my compressor to the fill valve and open and turn air on @ 20 # pressure. I open faucets and blow out lines. I do move from faucet to faucet throughout the coach after initially having them all open. When completely blown out I disconnect the compressor.
I open all faucets and remove the heads on the kitchen faucet, Shower Head, toilet sprayer head, disconnect water and ice lines on the fridge as well as the main water line feeding the fridge and remove the fridge filter, I leave the water heater tank plug loose. I disconnect the lines to the water pump which on my rig is very accessible.
Last step I put antifreeze in the sink traps and some in the toilet bowl.
I do not put any Antifreeze in my tanks as I do not want the residual taste
Make sure all black and gray water tanks are empty
Sometimes I am perplexed at how some people view protecting water system from freezing. Just some thoughts of mine--drains should drain....aka slope downwards...to drain. I don't know a lot/all RV water systems, but that's how it should work...and does in residential construction.
What I've done is to open the drains and let the water drain out, including water heaters.
Bump a pump to get any residual water out of it.
Pour into any traps/drains a small amount of 'anti-freeze' to address any standing water.
Never had a problem with freezing lines.
When I rebuild a camper, I strictly use pex as it can freeze up and not have any problems. I also make sure there's a drain in there for later for me. There shouldn't be enough water leftover in any fittings to cause any damage if it drains correctly.
One thing I don't care for though is in an RV water tank, the water supply outlet is a few inches off of the bottom, so it's hard to get that standing water out of it. I might get a small water pump to stick in there at the end of the season to suck out the bottom of the tank but so far, if that feezes I've not had any problem with it. Must be it's allowed to expand upwards. I just don't like standing water.
I buy 3 gallons for my class C. Just make sure you bypass water heater, but don’t forget to drain water heater first.
following up on this, i used about 3.5 gallons. i used the rest of the 4th bottle and put it in the black and grey tanks just in case they aren't fully empty (i emptied them, but there's always residuals).
I used 2-1/2 gallons in our previous travel trailer and about 4 gallons in our current 5th wheel. I drain everything with the low point drains first and then pump in the pink stuff. The dishwasher used more than I expected, but it wasn’t bad.
