Clearing out the pink stuff
breal14
New England
Four Winds by Thor
Chateau 24T sport
E450
V10 Triton
So, i stupidly got some pink antifreeze into my fresh tank when i winterized it (first time). apparently i did something wrong and used the pump incorrectly and it all went into the tank as well as the lines.
Didn't have time to mess with it in the winter... it was the night before a freeze so i just needed to get it done and so far, it looks like nothing popped so i guess i did ok there.
Now, it's spring, and today's self is calling last fall's self an idiot.
While we never drink the water, and i understand it's not toxic, i don't know how well i can actually flush it out. we do wash hands and the kids occasionally forget and use it on their toothbrushes/etc.
Planning to fill it up, drain it, fill it, drain it, fill it, drain it, fill/bleach it, drain it and leave it dry as i can with all drains open.
a week or so later, fill it for use with a tablespoon of bleach, hoping that's enough before heading out for the first trip.
I always added pink to FW tank, about 6 gallon of pink stuff to winterize, then in spring fill and drain FW tank 2-3 times, then bleach and rinse again, we also never drink it, never an issue, your plan is good, but more like a 1/4 cup of bleach, google the ratio per your gallon size
Propylene glycol is what that Pink stuff is in most cases. You should Make sure that is what you bought.
I thought you might be relieved by the following information.
Common Foods Containing Propylene Glycol
  • Baked goods and sweets: Cakes, frostings, candies, and ice cream.
  • Condiments and meals: Salad dressings, barbecue sauces, and frozen prepared meals.
    • Beverages: Soft drinks, flavored iced teas, and various drink syrups. [1, 2, 3, 4, 5]
Since you have pink in your tank, you are correct that multiple rinses is the way to proceed. I use Thetford cleaner and sanitizer. I would use these products to clear out traces of the pink, and avoid bleach. Also, I'm sometimes brave enough to just blow out my water lines for cold weather.
