breal14
- Jan 9, 2025
- New England
- Four Winds by Thor
- Chateau 24T sport
- E450
- V10 Triton
That's all I've ever done to include draining the water heater. Doing two rounds @ 30-35 psi, letting the lines pressure up then opening one valve at a time until only dry air is coming from the outlet. A few pints of RV antifreeze in each p-trap and it's all good.Likely 3-4 gallons. I open low point drains, blow the lines out and keep the inside around 68 during the winter. Close the low point when blowing out the lines, do one at a time about 45 lbs pressure. I use a small heater inside. I don’t use the antifreeze in the lines, only in the drains. Just enough to fill the p trap. My drains should be good with the inside temp but just to be safe.
If you park it at home I would keep it warm inside during the winter.
I use one gallon.24' class C, pretty standard set up.
40-45 gallon tanks all around.
how much pink stuff should i buy to plan for winterization next month. 1 gallon? 4 gallons? 10 gallons? i have no idea what i need. Anyone have advice?
adding it to my october subscribe and save discount on amazon![]()
