Fleetwood bounder starter spinning
Powrie
I have a 2004 Fleetwood bounder, workhorse 33w, engine will start as soon as you turn the key when engine and starter is cold, but after engine running for a while, engine and starter hot, the starter will spin, takes three or four times with the starter spinning then it will start, is this the relay, solenoid, or starter
Thanks
Starter Solenoid Problems​
The starter solenoid has four common problems:
bad starter solenoid
1) The suction fails occasionally, or works in engine cooling only and fails in engine warming up.
2) When starting up, the starter solenoid can not reset. Release the start button, the starter remains in operation and only stops when power off.
3) The elastic force of the return spring weakens after repeated use, resulting in that the drive gear of one-way clutch cannot be restored timely, but driven and reversely dragged by the flywheel ring gear.
4) When the starter starts, it will make a periodic noise from the starter solenoid, but the starter does not rotate.
