Dingus6772
- Dec 5, 2021
Thanks @BulyI’m guessing, the pump can not prime itself when the water level drops. How is the mounting level of the pump, compared to the tank? Higher or lower from the tank?
That makes perfect sense. I've replaced the pump recently. I'm guessing I need a low profile pump, possibly one that doesn't need to be primed. Thanks so much.I’m guessing, the pump can not prime itself when the water level drops. How is the mounting level of the pump, compared to the tank? Higher or lower from the tank?
Thanks @Buly
The pump has been replaced recently and that makes perfect sense. I'm wondering if there's a replacement pump that's low profile and doesn't need a prime. Thanks again
Nothing said that a "new" pump is not defective. After all, it is only new, which is not necessarily evidence of it being good.Well it is a new pump and I cannot mount it any lower and I cannot raise the tank. Is there a different kind of pump you can suggest?
Gotcha, thank you very muchNothing said that a "new" pump is not defective. After all, it is only new, which is not necessarily evidence of it being good.
Also, make sure there are no air leaks on the intake side of the pump. And make sure the tank vent is not obstructed. Otherwise, the pump will be pulling a vacuum on the tank and at some point, won't pump water.
The pump is on the same side as the suction line and the sensors are reading correctly. The tank is approximately 50 to 60 ish gallons. Every since I changed the pump it's been doing this. I figured my wife was using to much water and didn't think anything of it. The sensors say it's half full and I usually drain it before I store it and noticed it was half fullChances are it is like another trailer that I had. The tank was about 8 inches deep, the inlet (gravity) was on the side and the pump suction was on the side also. I calculated the 'loss' due to where the fittings were and it amounted to almost half the tank capacity. You need to see where the pump suction line is and see how close to the bottom it is. Also, verify the sensors are sensing correctly. What is the capacity of the tank?
Thanks @GronkThe pump is on the same side as the suction line and the sensors are reading correctly. The tank is approximately 50 to 60 ish gallons. Every since I changed the pump it's been doing this. I figured my wife was using to much water and didn't think anything of it. The sensors say it's half full and I usually drain it before I store it and noticed it was half full
I could tell it was half full because once I opened to drain, 25 gallons spilt outThanks @Gronk
