Full Wall Slide support shaft gasket
Richpatty
Wesley Chapel, NC
Ventana 4310
400hp
2007 CR-V
Hi All,
The gasket that helps "seal" off the basement storage where the support shafts slide into to the RV has become brittle and are crumbling. Have any of you gotten creative to replace it with something other than the standard slab of rubber Newmar used?
Let me know.
Thanks everyone!
Rich
Following. Some of ours tore within a few months of owning our coach. Replaced while at factory but the process is starting again.
Email parts and see what they say?
I haven't reached out to them yet, although I can tomorrow. I feel like they may just refer me to a rubber(ish) board that will disintegrate again. I was hoping the brains on the forum would have come up with something better. :)
I don’t even know what the point of that would be. With those huge gaps, it can’t be keeping much of anything out of there.
But I will say this @Richpatty, given the number of self tapping screws they used to secure it to the RV, they were clearly concerned about you driving down the highway with your slide extended.
Ok. Work has been crazy…so revisiting this. So what is the email address of the parts department?
Thanks. Will let you know what he says.
Has any of you had this issue?
I wasn't impressed with the seals on mine either. You could feel the heat pouring out of the basement. I had some 1" closed cell foam and cut it out to fit the hole on top of the factory seal. A little bit of weather strip cement keeps them in place when slides are deployed. Also sprayed a bit of rodent repellent on them for good measure.
Doesn't look to exotic, sheet rubber could be used to fab a replacement. Save as much of the original as possible to template it.
If it was me, I would use more self tapping screws. If you use enough, then you will convert your rubber into a metal flap. [/sarcasm]
Mine has a bit of inset to it so I was able to install over the top of the factory one. They weren't very degraded, just a poor fit.
Heard back from Newmar…they have the part…
“PN 125681 - $9.69 each. In Stock”
I will be ordering three…
OK! Ordered three gaskets and installed them last week. They came all precut and ready to install.
Hoping they last. I put 303 on them to keep the from drying out.
Oh, that's what they are supposed to look like... I think I have some rubber from a pond liner...will have to fab a few up.
Our 2020 has brushes, all bent out of shape and opened up, but maybe not on this shaft… Replacing soon. Side benefit I learned basement lights on from their gap while fixing power cord gasket. One thing leads to one more.
Digging up this old thread to say that I have replaced thee twice and they just don’t hold up. And I don’t even travel that much. Are others having this issue? Or has someone come up with an alternative?
Rich
