Furrion rear view camera.
billnourse
I have a Furrion camera mounted to a Forest River XLR Nitro using the prewired connection. This camera is on all the time. My batteries are draining in less than 12 hours and I am suspecting that the problem is the camera. Any thoughts???
The rear view camera should be powered from the “accessory “ circuit. Meaning it should be ON only when the ignition key is in the ON position. You, or someone knowledgeable should trace on the 12V fuse board which circuits are hot when the ignition key is in ON position,
And connect the camera to that fused circuit. That way the camera will be OFF when engine is off.
Me thinks?. I may be wrong?
