Question RV overhang in the rear.
Old one
Altamonte Springs, Fl
I asked a question a while back re: rear overhang in an RV. I used the terminology: Bumble bee look. I was looking for info in SAFELY driving it w/o someone smacking into it while I was negotiating a corner> One such tight turn is necessary in returning from an outing; however the city enlarged it so school buses can go thru w/o going over the sidewalk.
Being a retired scientist, maybe I am looking to an answer to a question that does not exist.
More info: I am presently trailing a 24' boat on an aluminum trailer, of which is 31' long from hitch ball to outdrive hanging out the rear. The distance between the trailer wheels to the drive is about 8', and I can handle it even before they enlarged the street width at the corner.
Am I trying to find something here that does not apply? If so, say so.
I am looking at class A and Class C motorhomes 24-28' and some are 10' hangover.
Thank y'all for putting up with me.
OK! So, what is really the question? Besides the various length features you also need to consider weight total and distribution, the tongue load. As for the long overhang the gassers have that to keep wight off the front axle as with only 2 tires up front that is a limitation. As for a trailer following making turns the long overhang helps with the inside corner as it will swing the trailer out further.
I believe you are overthinking. More problems are clipping corners.
Well, the boat is narrower, but yah.
The one corner that I have locally is used by full sized school buses, an dthey used to run over teh curb. The city widened the corner for them, so, as said maybe I am overthinking it. Once and engineer, always an engineer.
Some of the school buses have worse overhangs than the RVs.
So What’s your question ? (Swing) when turning…. looks like you received some help. Good luck.
