DAKC
- Feb 2, 2022
- Hilton Head, SC
- Coachmen
- Galleria
- 24.5 feet
- 5000lbs
2019 Coachman Galleria 24T: When I press the start button on the Firefly for the generator, I get a clunk sound and the indicated battery charge goes from about 14.4v to 10.2v immediately. For another attempt, I tried with shore power connected, same result. Another time I started the Sprinter and let it run for 10 minutes, and while running I then tried to start the generator, same result. The start was for the monthly run which has worked fine in the past. Backing up to the very first try, I had forgot to turn on the propane switch when I first tried the startup and the generator turned over but of course would not start. When I tried again, the above happened. I had let the house batteries charge overnight before I tried again. Later, I turned off the shore power to check the battery charge indicator. It read 14.4v. I then put a load on the battery by turning all of the lights on. The lights started flickering as well as the Firefly panel and the battery indicator dropped to about 10.4v immediately. I am not sure where to go from here.
